cRIO not configurable in MAX 16.0
I have a cRIO9036 and a expansion Chassis 9149. I have installed MAX 16.0 and the latest NI CompactRIO Device Drivers August 2016.
I can see my Chassis but i have no access on it and there is no Target and Devices/Software subdirectory.
MAX says "inconsistent ip settings".
I already verified my IP config.
When i open MAX 15.3 on other PC it works fine.
Does someone have an Idea.
thx
(3,233 Views)
When I have seen that error, it is usually due to my PC having an IP Address that is not on the same subnet as the cRIO.  If you really want to play with it, I recommend using the USB connection, which uses Ethernet Over USB.
(3,220 Views)
Accepted by Simonh.
Thank you four your Reply. But the same problem with USB connection.
I found a solution with downloading the NI System Configuration 16.0.1
This patch resolve the Problem with IP conflict.
https://www.ni.com/en/support/documentation/supplemental/16/ni-system-configuration-16-0-1-patch-det...
(3,206 Views)
