cRIO stand alone
I am using a cRIO system with 9004+9104 and nowadays I am working on stand alone operation. I have constructed a simple project to try on cRIO and do all the instructions at LV help stand alone RT step by step but when I power on the cRIO there is no operation at the controller. I have attached the files below.
(4,358 Views)
Hey,
Make sure that you Right Click on the real-time build specifications and select "Set as Startup". Kindly look at the attached screenshot.
Also make sure that all the DIP switches are in the OFF state on the cRIO. Check out page 8 on operating instructions at this link.
Chetan K
Application Engineer
Message Edited by CKap on 08-28-2006 11:37 AM
(4,331 Views)
Hi Chetan,
You are right, when I select "set as startup" then it works fine.
(4,323 Views)
