cRIO9004 Error 1003 trying to run thermocouple module NI9211
Dear all,
I'm trying to run cRIO model 9004 to do the example on the heat sensor using the model NI 9211. I doubt the VI itself is broken because I'm able to run it fine on an emulator.
However, I run it I get an Error 1003:Module Generator Broken  C:\Program Files\National Instruments\LabVIEW 8.5\Targets\NI\FPGA\RIO\CompactRIO\cRIO-91xx\cRIO-9104\cRIO-9104_TopLevelImplementation.vi
I have checked that file and it is indeed cannot be runned.
Do I need to replace that file with a new one?
I have included all vi's including the broken & pictures of my run result as an attachment.
Feedback is much appreciated.
Best Regards,
Sultan S.
(3,114 Views)
Sultan:
It does indeed sound like one of the software modules or dependencies is broken or incorrect. The easiest way to fix this will likely be to repair your LabVIEW FPGA installation and reinstall your NI-RIO driver. That should roll over any missing or broken files and get the module generator corrected.
Hope that helps!
Caleb Harris
National Instruments | http://www.ni.com/support
(3,107 Views)
