Using CD parametric time response.vi to get that same data for closed loop transfer function
Hi;
I have a closed loop control system using Fuzzy Logic as a controller, by using the CD parametric time response "in Control and Simulation Module" I found the overshoot and rise time and other parameters for the open loop.
Now I want to use the same vi or any other vi to find closed loop parameters.
Can anyone help?
Regards
Bakhtiar
(3,540 Views)
Hi Bakhtiar,
Thank you for posting on our forums, I am currently looking into this query for you.
By any chance could you attach your code for me to look at?
Many Thanks,
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
(3,531 Views)
Hi;
Please find attached the code, I want to determine the closed loop parameters such as overshoot and rise time using CD parametric time response.vi or any other possible techniques.
Regards
(3,525 Views)
To determine overshoot or rise time values you will need the Jitter analysis toolkit as there is a handy vi called 'Overshoot and Undershoot.vi'
Details can be found here: http://zone.ni.com/reference/en-XX/help/373270A-01/lvjitterphtk/overshoot_and_undershoot/
John McLaughlin
(3,515 Views)
