cRio-9068 How to enable the embedded UI and control FPGA VI from Host VI?
Hello Colleagues,
I would like to Enable the embedded UI on RT Target.
Device is cRIO-9068.
I'm trying to follow instructions from NI resources and enable this feature via NI MAX:
https://www.ni.com/docs/en-US/bundle/labview-real-time-module/page/lvrthowto/deskenv_enable.html
Unfortunately, I don't see the field  Enable Embedded UI checkbox in Startup Settings. Could be that is a lack of some software installed?
Could You support me with some hints, please.
Thank You.
(22,276 Views)
Accepted by topic author Tom_wolf
Hello!
The cRIO-9068 doesn’t support an embedded UI. Only x64 Intel chipsets support an embedded UI. The cRIO-9068 is ARM based.
Additional info:
Which NI Real-Time Targets Support Embedded UI?
Real-Time Operating System Compatibility
(22,233 Views)
