cRio 9068 appear labview but It doesn't appear in NI MAX
Some time ago I'm working with this cRio. but now it doesn't appear in NI max but I can programmer it through LAbview. Only  NI-max doesn't show cRio.
I need to see it to install a software.
(6,406 Views)
Hello fferrada;
The 9068 can handle two different modes; windows or as an RT target.
Using the cRIO as an RT device
If I understand correctly you are able to see your cRIO in your project; however if you can't see it in MAX ,then you will not be able to run your application or right click the device and connect to it....
The software you need to install in order to discover an RT device in MAX is:
Application software on development computer:
NI LabVIEW
NI LabVIEW RT
NI LabVIEW FPGA (optional)
Drivers on development computer:
NI-RIO
You also need to connect your computer to the cRIO with a crossover cable (if you are using a laptop you can use a straight one)
You can find the step by step guide page 14 or in the getting started
After seeing the cRIO in MAX; you may need to install software on it; I would use the "recommended" section that installs NI-RIO, ScanEngine and many frequently used tools.
Hope this info helps
Cheers
(6,391 Views)
But  I can run the aplication in  labview . despite cRio doesn't appear in NI MAX.
 These software  was installed. otherwise I couldn't  run my aplication.
yesterday when  I saw  MAX I realised that doesn't appear.
(6,384 Views)
Accepted by fferrada
Have you tried to manually add it in MAX, right clicking Remote Devices and adding it by IP adress??
(6,381 Views)
of course, but  didn't work
(6,378 Views)
