cRio folder doesn't appear in labview
Hi @all,
I setup a new system with a cRio-9035 controller and a LabView 2021 version. Now I have the problem that I can't add the cRio to a project in LabView.
Even under the option "Add target and devices" the whole "Realtime CompactRio" folder is missing.
In the device manager and also in MAX I see the cRio controller and even update the software on it.
Some additional information to the system:
- host pc Windows 10
- LabView 2021
- LabVIEW FPGA Module 2021
- LabVIEW Real-Time Module 2021
LabVIEW Professional Development System 2021
- NI CompactRIO 21.0
- on the cRIO-9035 controller: NI Linux RT - systemimage 21.0
I already found two posts with the same issue but couldn't solve the problem with them:
https://forums.ni.com/t5/LabVIEW/LabVIEW-does-not-recognize-CompactRIO/m-p/4154425
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019P6zSAE&l=de-DE
After this I checked the right order at installation (labview + fpga module + realtime module + driver), but it still doesn't work.
Does anyone else has an idea what the solution for this problem could be?
Thanks in advance!
(1,957 Views)
Hey,
Where you able to solve your problem? I'm facing the same problem, even though I believe that I have installed the right versions of the software and in the right order (labview + fpga module + realtime module + driver). I also tried going through the links you provided, but still nothing.
The versions of the software I have are exactly the same as yours, i.e. 2021.
Thank you in advance!
Kind regards,
Hossein
(1,843 Views)
Did you install 32 bit or 64 bit LabVIEW?  I believe cRIO is 32 bit only.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(1,830 Views)
Thank you for your answer, changing to 32-bit LabView solved the problem.
(1,820 Views)
