How do I extract data from a program based on NI 9237
I am measuring strain using strain gauges connected to NI 9237 and compactRIO controller is NI 9063.
I have run the example VI which is found in the CompactRIO /module specific 9327 Getting Started project.
I cannot get the final data in any format such as Excel, Node Pad, or TDMS. I try to use the  Write To Measurement File or I created a program that converts the results to a TDMS file, as shown in attached file but when I run the program, the results file does not appear.
Message 1 of 9
(2,009 Views)
@Mahdy81 wrote:
..., as shown in attached file ...
There is nothing attached.
Message 2 of 9
(1,982 Views)
Message 3 of 9
(1,973 Views)
Well, an picture of the block diagram only tells 1% of the story and is pretty useless. Why don't you wire and display some of the error out of the various functions so they can potentially tell you what's wrong?
I assume that this part runs on the RT system of the CompactRIO, so the file will be written (assuming the path is valid) on the local HD there, not on the PC.
Please explain in detail:
  • Where is this part of the code deployed? PC? CRIO?
  • What are all the control values (paths, etc.)
  • What are the error messages once you decide to wire the error outputs?
  • etc.
Message 4 of 9
(1,965 Views)
As shown hereby in the attached photo, I use the 9327 Getting Started project with FPGA,
and the program run well after the FPGA compiler without any error, my problem is how to extract the data from the program to excel format
Message 5 of 9
(1,960 Views)
I wait until you answer all my questions before continuing to troubleshoot this further.
Message 6 of 9
(1,957 Views)
the answers to the quations
- Where is this part of the code deployed? PC? CRIO?
as shown photo in CRIO
- What are all the control values (paths, etc.)
it is typical of the NI 9327 Getting Started project without any modification.
- What are the error messages once you decide to wire the error outputs?
the are no errors messages that come and at the same time no output is shown
Message 7 of 9
(1,952 Views)
I don't know what the default control values are, but I am sure you can tell us what the actual paths are (for the tdms code train and for the express VI).
Message 8 of 9
(1,947 Views)
 The complete project has been attached, the problem is the data don't transfer from the FGPA to TDMS function
Message 9 of 9
(1,923 Views)
