 Mahdy81
			Mahdy81
			08-12-2022 08:50 AM
 altenbach
			altenbach
			08-13-2022 01:56 PM
08-14-2022 07:55 AM
 altenbach
			altenbach
			08-14-2022 10:27 AM
@Mahdy81 wrote:
I cannot get the final data in any format such as Excel, Node Pad, or TDMS. I try to use the Write To Measurement File or I created a program that converts the results to a TDMS file, as shown in attached file but when I run the program, the results file does not appear.
Well, an picture of the block diagram only tells 1% of the story and is pretty useless. Why don't you wire and display some of the error out of the various functions so they can potentially tell you what's wrong?
I assume that this part runs on the RT system of the CompactRIO, so the file will be written (assuming the path is valid) on the local HD there, not on the PC.
Please explain in detail:
08-14-2022 11:44 AM
As shown hereby in the attached photo, I use the 9327 Getting Started project with FPGA,
and the program run well after the FPGA compiler without any error, my problem is how to extract the data from the program to excel format
 altenbach
			altenbach
			08-14-2022 11:47 AM
I wait until you answer all my questions before continuing to troubleshoot this further.
08-14-2022 12:35 PM
the answers to the quations
- Where is this part of the code deployed? PC? CRIO?
as shown photo in CRIO
- What are all the control values (paths, etc.)
it is typical of the NI 9327 Getting Started project without any modification.
- What are the error messages once you decide to wire the error outputs?
the are no errors messages that come and at the same time no output is shown
 altenbach
			altenbach
			08-14-2022 01:49 PM
I don't know what the default control values are, but I am sure you can tell us what the actual paths are (for the tdms code train and for the express VI).
08-16-2022 02:35 PM
The complete project has been attached, the problem is the data don't transfer from the FGPA to TDMS function
