can not find cross compiler to download
On the page for cross compiling:
https://nilrt-docs.ni.com/cross_compile/config_dev_system.html
Its says
"Navigate to the ni.com/downloads <https://ni.com/downloads> page and download the GNU C & C++ Compile Tools for ARMv7 or x64"
or
"Download the NILRT CrossCompile Toolchain installer from ni.com/downloads"
But searching ni.com/downloads I can not find anything close to matching either of these two names. Please can someone provide the relevant link and it would be good if the documentation was updated.
(1,164 Views)
The toolchains are linked in the Required Software section of the page:
Agreed, finding the toolchains from the download page is not intuitive. The instructions need to be revised.
If you are a new to cross-compiling for the NI Linux RT targets, you will come see references to Eclipse packages. Do not use the Eclipse toolchains, they can be difficult to configure. Eclipse is still available as it is required for Veristand development.
(1,134 Views)
I looked on the site and can not find the page you've screen shotted. Can you please provide a link?
https://nilrt-docs.ni.com/cross_compile/introduction.html#id8
(998 Views)
The 4th one of your links was what I was looking for. Thanks!
(995 Views)
Hello everyone,
I am setting up the cross-compilation system following the instructions in https://nilrt-docs.ni.com/index.html.
I am trying to compile for an armv7 target with an image from 2017, so I download the compile tools for host OS windows and version 2017:
[GNU C & C++ Compilers for ARMv7 Linux (Windows host) 2017]
However, the setup script in the compressed file is a linux executable, not a windows executable as described in the documentation, so I can not run it and am stuck at this point.
Was this repository moved? Did anybody have a similar problem?
Thank you in advance,
Juan
(877 Views)
