can we use sbRIO 9607 USB port as a storage device?
i was wondering that can i use the USB ports as if the sbRIO is a storage device, like its ftp interface which we connect via ethernet port, i want to see its internal documents via USB is this possible ?
thanks in advance
(3,327 Views)
Accepted by tada93
The sBRIO 9607 is a controller running the NI Linux Real-Time operating system. It has 512 MB of internal storage that you can access via FTP. For Linux devices, we recommend WebDAV for file transfer:
Using WebDAV to Transfer Files to Your Real-Time Target:
So, the answer is yes. Hope this helps.
CH
Applications Engineering
http://www.ni.com/en-us/support.html
(3,300 Views)
thanks for help, i think this should work, I'll give it a try
(3,289 Views)
