compact rio ni-9219, how do i convert the tc measurement to voltage or temp.
I HAVE A CRIO9072 SYSTEM, WITH SEVERAL NI-9219 MODULES.  I'M NEED TO KNOW HOW TO CONVERT THE VALUE THAT THE MODULE READS TO EITHER A VOLTAGE OR TEMP.  THE ONLY SELECTABLE SETTING I HAVE IN THE FPGA VI IS VOLTAGE RANGE WHICH IS 125mV FOR TC.  PLEASE ADVISE
(3,288 Views)
Hi AAON,
Please go to Help»Find Examples, and look at the example called "NI 9219 Getting Started."
This project has both FPGA and Host VIs demonstrating how data is usually acquired and presented from a 9219 module through a CompactRIO.
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
(3,273 Views)
