crio 9038 not turning on
today out of nowhere the crio 9038 in my university does not turn on, i push the start button for few seconds as usual but it does not turn on, any idea how to possibly troubleshoot it?
thanks in advance.
(1,504 Views)
Have you checked the power stage of CRIO? Any burns or etc. you can see?
(1,476 Views)
Accepted by rached
Hi Rached.
In addition to what Hepguven said.
I would also ask that you verify if any LEDs are on, to to power it on with no modules in it and that you check that the voltage level of the Power supply is within the recommended specs.
If after this you still see no action on the cRIO I can recommend that you contact NI, in order to get a repair going.
Kind regards
LabVIEW Fairy
cRIO Enthusiast
Please mark solutions when appropriate.
(1,457 Views)
