crio doesn't save the program
Every time we turn on the machine we have to re-download the program. What can we do to fix this?
(4,758 Views)
Hi Camobot1,
What type of program are you using?  Is it a Real Time vi or is it an FPGA vi?  Or is it a RT application.
What type of behavior do you want?  Do you want the program to run when the cRIO is powered on, or do you just want to avoid the deployment time?
Ryan
(4,749 Views)
Real time VI.   We changed the "deploy at start up" and activated it. We still have to deploy the program on the computer every time. Seems like nothing is getting saved, therefore everytime we power up, we have to waste time and redownload/deploy the program.
(4,747 Views)
We are also unable to get our orange light to flash or light up as well. It is wired up the way the diagrams say. We get 12V positive off the furthest pin from our side car from the power supply. However we don't get any "negative" power out of the other pin.
(4,746 Views)
What version of LabVIEW and the NI-RIO driver are you using? Has the RIO always exhbited this behavior?
Patricia B.
(4,736 Views)
