 cosw
			cosw
			01-28-2010 09:58 AM
I've been trying to deploy my application to a cRIO-9002. But it will fail with the simple message "Deployment Completed with Errors." How do I find the errors? What can I do? I have attached the protocol of the deployment-progress.
Christian
01-29-2010 07:28 AM
you can have a look on the discussion below.
Link:
http://forums.ni.com/ni/board/message?board.id=170&message.id=453721&requireLogin=False
Could you post your RT-VI?
Regards
Rüdiger
 LabBEAN
			LabBEAN
			10-22-2010 08:24 AM
We're seeing this as well (LabVIEW RT 2009 SP1, NI-RIO 3.5.1). The message goes away after reinstalling software onto the cRIO (through MAX). Then, it eventually comes back. Rebooting is no help and we've upgraded to the latest version of NI-RIO (3.5.1) and the problem persists (that is, everything works for a while and then the "deployment completed with errors" message eventually returns when trying to run a VI on the controller from the IDE). It looks like an FRC team saw this as well.
While we started at NI-RIO 3.2.0, our controller (cRIO-9012) is not one of the ones listed with the solid state harddrive problem associated with NI-RIO 3.2.0.
 LabBEAN
			LabBEAN
			09-18-2012 10:00 AM
Got this error again today and theorize it was related to the controller running out of memory during deploy. In this case, I'm working with a cRIO-9004 with 64 MB of memory.
