difference between real time module and fpga module
Hi experts,
I was wondering if someone could tell me (in a nutshell) the difference between the FPGA module and the real-time module.
My understanding is the FPGA module facilitates LV code that can then be targeted at specific RIO boards, I have used this a little in the past.
The real-time module I am a bit more unsure about, all I know is that it allows for creation of a "real-time" i.e. time deterministic environment.
My application is this: I wish to have several control loops running on two RIO boards, with the host PC mainly being used for logging of data and UI business. So as far as I can see I do not need RT on the host (Win XP should be fine).
Do I need the RT module???
(4,716 Views)
Additional info: the RIO boards will probably be 2x PCI-7833R
(4,715 Views)
Accepted by Neil.Pate
You are correct.  In the scenario you describe, you will not need LabVIEW RT. LabVIEW RT is used to create deterministic execution on specific intel targets like the PXI-8106 and PXI-8108.  You can still use floating point and strings on RT.
Stu
(4,696 Views)
OK thanks, I was hoping somebody would say this!
(4,640 Views)
