error code -1073741515 FPGA compile
Hi fernholz
Thank you for a report.
 I try a reinstallation. And I report a result.
Message 11 of 13
(1,890 Views)
Hi fernholz,
I deleted all of 8.5.1(LV8.2.1/8.5.1,RT,FPGA,VISION, and ...).
I installed it in the back again, but was not able to compile it.
I erased deletion of all software related to LabVIEW and all the registry related to Xilinx. I got possible to compile it when I installed software except VISION again.
I think that there was a problem to registry of Xilinx or LabVIEW-related registry.
Message 12 of 13
(1,869 Views)
Hi gogomac,
I'm not sure if I'm understanding very well whether or not you are able to compile. My understanding from your post is that you were able to compile once you removed all NI software and reinstalled everything except the Vision software. Is this correct? Also, does that mean that when you install the Vision software, it does not compile anymore? If so, what Vision software are you installing? Also, what operating system are you using?
Thanks!
Message 13 of 13
(1,850 Views)
