etherCAT:disable Distributed Clock kills Digital outputs
I have seen this happen on one of my cRIO's.  I had disabled the distributed clock on the etherCAT chassis and forgot about it until
diagnosing a problem with digital output no longer working in the extended chassis.  After renenabling the distributed clock the digital I/O started working correctly.
Has anyone else seen this problem?  I was under the impression that this distributed clock only proved hard frame sync to the extend chassis and all I/O should work
without it.
(3,953 Views)
When you disabled the distributed clock, were you using 'unsynchronized' or 'synchronized to EtherCAT frame'?
I'll give this a try when I get in tomorrow and see if I can replicate it.
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(3,938 Views)
Sachsm,
So, after disabling the Distributed Clock, my digital I/O still worked when using the 'unsynchronized' option, both with while loops and timed loops synched to scan engine. When I used 'Synchronize to EtherCAT Frame', my I/O no longer worked.  The only reason to ever disable the distributed clock(also known as free-run mode) would be to use third-party masters that have difficulty with the distributed clock. Is there a reason you were disabling it?
Rob K
(3,924 Views)
Yes, I was originally trying to diagnose a problem with the Software Sync (1588) beta and was advised to try to disable the distributed clock.
I am finding that the problem on my cRIO's (2 of them had this problem) is now gone and I am not able to replicate.  Somehow the cRIO was put into
a funky state and even in the DSM I was not able to set a Digital Output.  Not sure what caused the problem but thought it would still be good to throw it out there since it was certainly real while it was happening.
(3,922 Views)
