rt
I have seen this happen on one of my cRIO's.  I had disabled the distributed clock on the etherCAT chassis and forgot about it until
diagnosing a problem with digital output no longer working in the extended chassis.  After renenabling the distributed clock the digital I/O started working correctly.
Has anyone else seen this problem?  I was under the impression that this distributed clock only proved hard frame sync to the extend chassis and all I/O should work
without it.
(3,334 Views)
(3,332 Views)
Please use http://forums.ni.com/ni/board/message?board.id=280&message.id=6269&jump=true#M6269
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(3,306 Views)
