08-14-2017 08:34 PM
I'm working on getting an existing program to work on a new computer with LabVIEW 2016, and when I try to run the program, I have the following conflict resolution box pop up:
The error reads: "The EtherCAT master adapter does not exist on the target controller. There are three possible reasons:
1:The NI-IndCom for EtherCAT software is not installed on the target: Use Measurement & Automation Explorer (MAX) to install the software.
2:No adapter is configured for EtherCAT: Configure the adapter in Measurement & Automation Explorer (MAX), and make sure one of the Ethernet adapters is configured to EtherCAT mode.
3:Offline adapter: Go to the properties page and change the adapter to an existing adapter or remove the master item from the project tree, and try again.
Checking MAX, I see this:
I'm not sure if that means I'm connected or not. I've tried right clicking on "network devices", but I'm not able to find anything to connect with that way.
I'm also able to communicate through the command prompt (although this is a different IP address than what is shown in NiMAX):
Do you have any thoughts on what I could try next for troubleshooting?
Thanks for the help!
08-14-2017 08:48 PM
Can you please provide the snapshot of the "Network Settings" Tab in MAX? Let me help you check your EtherCAT settings.
08-15-2017 11:47 AM
Hi, I was able to get help from someone I know who is good with network connections. It had to do with finding the correct device IP address, and connecting to that. Unfortunately, I don't understand the details enough to post a solution. Thanks for your time, and my apologies.
08-15-2017 08:15 PM
No worries. Glad to hear that your problem is solved.
