examples on sbRIO-9642
         we are struggling with programming in sbRIO-9642 we have searched a lot for the example programs to run but we didn't get any thing so anyone please give us some example VI's that can run in LabVIEW 8.6 for sbRIO-9642. we are having RIO software 2.4.1 in both host and the target system.
thanks with regards,
P.Anand
(4,273 Views)
spanand,
You can use any of the examples for the CompactRIO system. Your only limitation is that you will not be able to use the Scan Engine examples.
Also, I would recommend a RIO upgrade if you can...there are many fixes since 2.4.1. For 8.6, 3.0.1 or 3.1.1 is a good choice.
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(4,139 Views)
