 Nabeloabbasi
			Nabeloabbasi
			09-30-2010 12:38 AM
hi to all
iam currently using labview 2009
and iam using NI hardware to work with my application
i have designed adaptive controler for adaptive noise cancellation in labview
now i want to use follwing hardware to implement my task
1.NI cRIO-9012(real time embeded controller)
2. NI 9201 Analog input module ( to take audio signal)
3. NI 9263 Analog output module(to hear audio signal as output)
how i configure these hardware on real time module
is any one can help me to start my application
thanks in advance
tc all
Solved! Go to Solution.
09-30-2010 04:39 PM
Hi TC,
It really depends on if you are going to be using the 9201 in scan mode or FPGA. Which do you plan on using?
10-01-2010 01:08 AM
thanks Justin_P
i want to use scan mode first for my application
i wan to use only analog input and output modules
as my application concerned i want to apply audio signal to input and distrubance to NI9201 then my controller will reject noise and i will get output through output module NI-9263
iam attaching one pdf file
which is helping as well
thanks
10-01-2010 03:00 PM
The article that you linked is a great starting point. Have you been able to out signals with the 9263 and read signals with the 9201 yet?
10-02-2010 07:28 AM
yes justin
i was having one more problem
which was the version of cRIO version
iam using labview 2009 sp1
so my real time controller (Ni-9012)which has NI RIO 3.4.0 version
that was not installed on my suystem that i have installed
for real time application it show some error when u connect input
or you can say for scan interface mode which is different from Fpga mode
the error was scan egine 1.1 missing
which i have installed now with the downlaod of NI RIO 3.4.0
now further i will see what problem i will face
more i will
thanks
10-04-2010 04:35 AM
hi justin
iam having problem to read output and input
the reason is of my chasis 9102 doesnot support ni scan interface mode?
can any one will help regarding that my problem
thanks
iam using labview 2009 sp1 with 3.4.0 cRIO model
 Verne_D
			Verne_D
			10-04-2010 11:58 AM
Hi TC,
You're correct that the 9102 does not support Scan Interface. There's a good requirements guide for Scan Interface here.
To move forward with your existing hardware, you'll have to write in FPGA mode. There are good examples for AI in the example finder under Hardware Input and Ouput > Compact RIO. If you don't have the FPGA module, though, you'll have to find a compatible backplane to program in RT only. Please post back with any questions you might have. Hopefully we can get you pointed in the right direction to be successful.
10-05-2010 01:10 AM
thanks
i ahve fpga module but my application task is adaptive noise rejection
that's why i want to use in real time
iam attaching one file
i have also tried using fpga module as well
by taking some analog output and input
if u see my file
i have correctly configure cRIO and analog module but when i run it show error
so plz help me in this regard
the link u have told
it is not opening
could u give me some good example how could i will do
iam attaching my experimental setup as well
thanks
10-05-2010 11:25 AM
I noticed that you said "my application task is adaptive
noise rejection that's why i want to use in real
 time".  FPGA is faster and more deterministic than RT.  If you could implement this in FPGA it would be better than RT.
10-05-2010 12:52 PM
hi justin
is mathscript node will work with fpga targets??
