how 9201is used for real time application?
Mathscript RT can run on the RT target, but not the FPGA itself.
Verne D. // Software R&D // National Instruments
Message 11 of 20
(3,245 Views)
thenks Verne D
i have tried mathscript RT work for real time
tc
Message 12 of 20
(3,239 Views)
Accepted by Nabeloabbasi
hi all
iam facing one more problem regarding
iam using  NI cRIO 9012 real time controller
for my application iam using simulation loop in my progam vi
is control & simulation loop can be compaitable with cRIO module??
because when i run my progra it shows error
Deploying NILVSim Get Time and IsAcceptedStep.viNILVSim Get Time and IsAcceptedStep.vi loaded with errors on the target and was closed.
LabVIEW:  Failed to load shared library NILVSim.*:SIM_GetTimeAndIsAccepted:C on RT target device.
i have read abt this error this the software regarding control and simulation loop is not installed on cRIO 9012
i have open MAX & manualy install it but it fail to load it
is cRIO 9012 real time controller is not compatiable with that or any other reason??
is any one can help me rgarding that my problem
thanks & waiting for reply
tc all
Message 13 of 20
(3,217 Views)
CD & Sim should work just fine on a cRIO if you have properly installed CD & Sim to the cRIO through MAX.
You said, "i have open MAX & manualy install it but it fail to load it." Did you get an error during installation? If so, what error? If you look under the "Software" section for the cRIO in MAX, do you see "LabVIEW Control Design and Simulation" in the list?
If all else fails, you could try manually FTPing the following file into the cRIO's system folder:
C:\Program Files\National Instruments\RT Images\LabVIEW Control Design and Simulation\9.0\NILVSim.out
Message 14 of 20
(3,203 Views)
thanks  dbohls
yes control design  & simulation9.0 is showing in Max but in un-instal format
i have done it by adding new software but it show error does't communicate
then as u said manually how i will find cRIO system folder
nd ftpinf it..
i have founf file NILVSim.out
tc
Message 15 of 20
(3,168 Views)
If there is some communication error, you probably won't be able to FTP anything to the cRIO. I'm not sure what you mean that CD&Sim shows up in "uninstall format". It would help if you were more specific about what you are doing and what error(s) you are getting. Consider explaining step by step what it is you are doing and what you are seeing. A screenshot or two might help also.
Message 16 of 20
(3,157 Views)
hi dbohls yes there was communication error whine installing CD & sim i have use another cRIO 9102 module & CD & sim is installed on it & working properly but for experience/ learning i was asking u how manually we install the software by ftping the required path
basiclly iam using simulation loop in my application task & i wan to implement it on real time target that's why iam using real time controller and compacr RIO modules & c-serious modules
tc
Message 17 of 20
(3,149 Views)
tc
Message 18 of 20
(3,149 Views)
Hi TC,
It sounds like you've got a different issue than where we started. You might have better luck posting to a new thread specific to this issue, that way users can see what you're currently asking about. Just a thought.
Message 19 of 20
(3,145 Views)
hi
 Verne D
yes ur right
ok iam closing this
thread
Message 20 of 20
(3,109 Views)
