09-13-2009 05:19 AM
sir
i made a system on that a dc motor is fixed to produce vibration. by using crio i wants to measure amplitude of vibration and its frequency and by this amplitude or frequency i wants to control speed of motor by pulse width modulation as if amplitude of vibration increases speed of motor should decrease for measuring amplitude of vibration i m using ni9234 and for output to motor i m using ni 9505 . i wants continous control of motor as amplitude value is changing.
please tell me how we can do it or send me any example .
thanks
09-25-2009 12:54 AM
Since you want to vary the motor speed with the vibration amplitude you measure you need the following toolkits :
1. Sound and vibration
2. Control design toolkit
You can use a PID control to vary the PWM in turn vary the speed of the motor. The following articles will help you through this:
http://zone.ni.com/devzone/cda/epd/p/id/5177
http://zone.ni.com/devzone/cda/tut/p/id/6143
When changing the period of the PWM on the NI 9505, any period is allowed EXCEPT for the following:
0 ns to 875 ns. In this range, the FPGA will command the H-bridge to send out pulses, but some of the pulses will not be sent out of the H-bridge chip.
1175 ns to 1800 ns. In this area, the behavior is undefined and sporadic (make sure not to run the motor in this area).
Kudos are welcome
