how to control pwm output which we r giving to ni9505 to control a motor?
sir
i made a system on that a dc motor is fixed to produce vibration. by using crio i wants to measure amplitude of vibration and its frequency and by this amplitude or frequency i wants to control speed of motor by pulse width modulation as if amplitude of vibration increases speed of motor should decrease for measuring amplitude of vibration i m using ni9234 and for output to motor i m using ni 9505   . i wants continous control of motor as amplitude value is changing.
please tell me how we can do it or send me any example .
thanks
mpsingh
(3,662 Views)
Since you want to vary the motor speed with the vibration amplitude you measure you need the following toolkits :
1. Sound and vibration
2. Control design toolkit
You can use a PID control to vary the PWM in turn vary the speed of the motor. The following articles will help you through this:
http://zone.ni.com/devzone/cda/epd/p/id/5177
http://zone.ni.com/devzone/cda/tut/p/id/6143
When changing the period of the PWM on the NI 9505, any period is allowed EXCEPT for the following:
0 ns to 875 ns.  In this range, the FPGA will command the H-bridge to send out pulses, but some of the pulses will not be sent out of the H-bridge chip.
1175 ns to 1800 ns.  In this area, the behavior is undefined and sporadic (make sure not to run the motor in this area).
Kudos are welcome
Shreyas Hebbare
Shreyas Technologies
India
(3,592 Views)
