initialize Shared variable network
I have sometime this code error : -1950679034 on my RT target cRIO-9064 and this stop my time loop (see in this attach). But just before I set this variable to False and in the second time when I launch again this value has no value and the default value is true and sometime it's stop my while loop. How to solve this issue. Thanks for your helps
(2,537 Views)
Accepted by GSXR100038
Post your actual VI.  People are hesitant to open up Word documents from the forums.
This is another thing I despise about Network Published Shared Variables: they can take forever to deploy.  What I have done in the past is write the value to the shared variable and then read it in a loop until you no longer get the error.  Then you can proceed to your main loop.
(2,527 Views)
After using a delay in a While loop to initialize Shared Variable Network it's will be fine. Thanks for your helps.
PS: it's not easy to send a VI without a projet
(2,521 Views)
