module enable
In my code,i have enabled the mods before using them as the 1st step but even after this implementation i find the 4th LED(Red) on the module(9505) turned ON when i run the code.
Not only that,by enabling this mod,the motor connected to it is expected to run but it ain't.
Pls help me out.
(3,668 Views)
Can you show the whole code?
First thing you need to make sure you connector the 12V-36V DC power supply to Vsud (C,V).  To run the motor, you need to drive true value to "Motor"
(3,649 Views)
Pls find the screenshot attached.
I have given True to motor and the power supply is properly connected.
I am able to read chassis temperature from this i understand that i am able to read from the mod but not able to send signal.
(3,632 Views)
Sorry for late response - NI forum was updating. Anyway, can you try something this simple?
(3,600 Views)
