"Save changes before closing?" message deploying CRIO VI
I have a compactrio 9002 with a 9102 chassis. I have made a project with an VI for the FPGA of 9102 and other for cRIO processor 9002. I have compiled and run FPGA VI without problems.
The problem is when I open the cRIO VI a message appear saying "Save changes before closing?" and it give the next : "EIO_InternalErrStrings.vi is about to leave the memory. Its unsaved changes will be lost". I have attached a picture of the message.
If I select Save it says to me I can't save the VI because it is a proteccted VI (see the image "try_saving")
Finally I select Don't save all an the VI loads correctly. But then when I try to run it, appear other message "Save changes before closing?" . I select Don't save all , and the VI starts to work.
I want to know if I can to avoid that message.
Thank you
(3,786 Views)
Don't take in consideration that... just say not to say and everything is fine... this is just a mistmatched timestamps between the real typedef savetime and the expected one.
Jaime Cabrera
NI Applications Engineering Spain
(3,775 Views)
