real time various errors
Did you use the Desktop Utility to format your hard drive for LabVIEW RT 8.6 ?
Sometimes this kind of issue can happen when you try installing softwares for LabVIEW RT 8.6 but when your computer is formatted for another version of LabVIEW RT.
So for ETS Desktops and other Real-Time targets, use the Desktop PC Utility to format the target for Real-Time 8.6. This utility is available in Measurement & Automation Explorer through Tools»RT Disk Utilities»Desktop PC Utility USB Drive.
You can have more information about that issue in this Knowledge Base.
Message Edité par Maxime MULLER le 09-05-2008 06:43 AM
Message 11 of 13
(1,258 Views)
Hello Sievel,
I've the same hardware and having the same problem.
Can you use usb flash disk to run desktop pc utilities like they said?
Do you still have the same problems with RT.
Here it's crazy to put only a machine to start...
Software developer
www.mcm-electronics.com
PORTUGAL
Message 12 of 13
(1,253 Views)
You can use the floppy disk utility too, to format your hard drive. Sometimes it's easier that way.
Message Edité par Maxime MULLER le 09-05-2008 06:59 AM
Message 13 of 13
(1,251 Views)
