sb-rio 9642 default ip 0.0.0.0 remains unchanged
Hi Umar,
You've given very detailed steps for what you've tried thus far, so that helps out a lot.  Has this device ever worked?  Is this your first time using it?  I would also suggest calling into support at this point, we may need to consider an RMA.
Bobby Breyer
Message 11 of 12
(2,759 Views)
It sounds like the disk may be corrupt, so I would suggest contacting support to see if you can RMA the unit.
Message 12 of 12
(2,757 Views)
