shared variable with RT FIFO initial value
The Good News:  It is possible to set the initial value of a NSV on an RT target.
The Bad News:  There does not seem to be anyway to determine when this initial value is available from the SV server.
For some reason there an initializing period of time that the PSP client (your RT application) needs to connect to the SV server to obtain the
current value of a NSV.  You can try looping until the warning message  (Warning -1950679027 occurred at an unidentified location
Possible reason(s):
LabVIEW:  (Hex 0x8BBB000D) NI-PSP has not connected to the server yet)
goes away but this does not alway guaranteee that the next transaction will be good.
I think NI should provide a utility that can be called that forces this initialization process to occur.  Putting the burdon on the LV developer
in this case is bound to be creating many frustrated engineers.
(4,741 Views)
Hi Sachsm,
While I do not have another work around for you at the moment I do want to note that the confusing behavior of Network Shared Variables has been previously noted in Corrective Action Request (CAR) #123473 and #123474. To add more weight to the CAR I suggest filing a Product Suggestion and mentioning the above CAR numbers when stating your application
For others that might not know, Shared Variable do have many quality codes that can understood from Shared Variable Error Codes.
Joshua B.
(4,715 Views)
This sure would be handy.  Any update on the CARs or clever work arounds?
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
(4,179 Views)
This behavior seems to have improved in LV2010, in my application I no longer have this issue.  But as LabBEAN points out, it would be nice to see a published CAR to verify what
changes, if any, were actually made.
(4,176 Views)
Hello all,
CARs 123473 is closed as fixed for LabVIEW 2009. CAR 123474 is still being worked on....
Joshua B.
(4,174 Views)
