9144 chassis without controller
Hello, Respected NI engineers!
I had a different interpretation of following articles.
How to use the NI 9144 EtherCAT slave chassis with 3rd party EtherCAT master tools?
and
Making NI 9144 chassis expansion PC based
As I have understood, in the first one is said that 9144 chassis can be used without the controler (cRio/PXI).
But at a forum (2 reference) it is specified that the controler is necessary.
Therefore a question: whether probably to use 9144 chassis (with support EtherCAT) without the controler?
(4,098 Views)
Hi kolan,
The 9144 requires an EtherCAT Master.  As the first article explains, this doesn't need to be a CompactRIO or PXI chassis, just a system that can act as a EtherCAT Master.  The forum also mentions the need for an EtherCAT Master.
Jared S.
Applications Engineering
(4,074 Views)
So, does that mean that we can use PC-based Ethercad Master cards such as are presented under the reference?
PC-based Control Systems, Soft-PLC
Thanks for Your reply, Jareds!
Kolan
(4,050 Views)
Hi Kolan,
Exactly.  A PC-based EtherCAT Master card should work just fine as long as it follows the EtherCAT standard.
Jared S.
(4,034 Views)
Jareds!
You have very much pleased me and not only me!Smiley Happy
(4,025 Views)
