05-04-2016 10:47 AM
I am working on a speed monitoring system of induction motor using NI cRIO.I have a rotary encoder but dont know how to make the hardware connection and which c-series module to use.Also I am confused whether the direct connection can be made.Can i use an IR sensor in place of the encoder?please help i need to complete this project....its urgent!!
05-05-2016 03:39 AM
What encoder are you using and what C series moduels do you have?
05-05-2016 08:42 AM
i am using E50S8-400-3-T-24 autonics encoder.I have NI 9421 module.Also tell me how to measure the speed(rpm).
		05-05-2016
		09:26 AM
 - last edited on
		06-05-2025
		01:36 PM
 by
			Content Cleaner
Try using this example, just add in the z line if you want, and replace the FPGA I/O nodes for ni 9421.
05-06-2016 10:52 AM
k thanks pal!!
