timing violation two channels/external trigger NI 7966R with 5772
PatrickR, if you are working with the TIS mode enabled example, you should take into account that the number of samples you read out from the "FPGA-to-Host" FIFO should always be 2 times the "Samples Per Trigger" you specify (CAR #406283). Helps?
Message 11 of 11
(2,664 Views)
