06-24-2013 06:04 PM
PatrickR, if you are working with the TIS mode enabled example, you should take into account that the number of samples you read out from the "FPGA-to-Host" FIFO should always be 2 times the "Samples Per Trigger" you specify (CAR #406283). Helps?
