Hi geeaile,
This happens because the exe retrieved from your RT target and vi on your host pc don't match, as the app builder optimises the exe. To get around the 'vi's don't match problem', you need to create a folder in your host computer "c:\ni-rt\startup" and place a copy of the built executable located in your RT system (c:\ni-rt\startup folder) in the same directory on your host pc (you can do this via ftp).
Hope this helps.
Message Edited by DavidT on 05-03-2005 11:35 AM
