unable to reconnect to target (FP-2000) when exe vi is running
Im'not able to reconnect to target (FP2000) when a exe vi is running.
*I'm using LV 7.1 with windows XP
When I connect to the target a window pop up and ask for the vi. I always have the error message that the vi is not similar.
I tested with a basic vi (a switch and a led) and I have the same problem.
Right now I have to stop the exe vi if i want to reconnect to the FP-2000.
(3,647 Views)
Hi geeaile,
This happens because the exe retrieved from your RT target and vi on your host pc don't match, as the app builder optimises the exe. To get around the 'vi's don't match problem', you need to create a folder in your host computer "c:\ni-rt\startup" and place a copy of the built executable located in your RT system (c:\ni-rt\startup folder) in the same directory on your host pc (you can do this via ftp).
Hope this helps.
Message Edited by DavidT on 05-03-2005 11:35 AM
(3,628 Views)
thank you! it work
(3,621 Views)
