wring of NI 9205
Thanks. My system is simple. A sensor can output 0-10 V signal, and I want to capture it to NI 9205.
We are seeing the same diagram. Yes, there is a Vcm. I think Vcm is noise voltage instead of a physical device. (Maybe I am incorrect). If you see V2, and its negative is directly connected to AI9, COM, and chassis ground.
I want to connect my sensor only to Al0 and Al8, and leave other channels open, including COM. But I am sure whether this way can make the measurement inaccurate.
Message 11 of 14
(706 Views)
Some sensors (floating) have two outputs — a + output and a - output. Vcm is not noise exactly. Vcm is common mode voltage—you have to make sure doesn't exceed the spec of 10.4V.
But, it sounds like maybe your sensor has just a + output. If so, that's a single ended source and that's part of what's confusing here of how to wire it. You might consider using the NRSE Voltage Signals wiring diagram
Message 12 of 14
(703 Views)
Thanks so much! I checked my sensor, it has a positive and a reference ground. Do you think my sensor should be wired using NRSE? Instead of Grounded Differential Signals?
Message 13 of 14
(689 Views)
Your sensor has effectively 3 terminals? Power in, ground, and voltage out? Then, yes, NRSE would be the first thing I tried. I expect it to perform very well. If for some reason it doesn't, the next thing I'd try is  Floating Differential Signals
Message 14 of 14
(682 Views)
