[Update]
This free toolkit is now available directly from the LabVIEW Tools Network and through VI Package Manager
[Update]
At SAPHIR we are used to put some helpful tools in our "VI Box". These tools help us every day in our LabVIEW developments. Today, we want to share (free of charge) our custom probes with you.
This is not revolutionary, we just hope that it'll help you to find and fix bugs in your code.
Installed probes are located in the wire contextual menu "Custom probes".
The following is a non exhaustive list of probes provided:
Probes are also available on numeric array, on boolean (scalar and arrays).
Probes containing graphs are resizable and provide you access to zoom tools and plots properties.
