Signal Conditioning
4-20mA temperature transmitter
Hi gang - newby here. I'm using a Honeywell ST250 2-wire 4-20mA temperature transmitter to send and record a continuous signal to a PCI-6025e. Is there any way to do this without an intermediate signal conditioner? I am clear on the need for a 250 ohm resistor to convert the 4-20mA to voltage, but I'm not clear on the wiring or the appropriate vi to use.
(3,987 Views)
It sounds like you are just getting started with data acquisition in LabVIEW.  Some great references for getting started are:
Learn 10 Functions in NI-DAQmx and Solve 80% of Data Acquisition Applications
For wiring your temperature transmitter, take a look at the Field Wiring and Noise Considerations for Analog Signals
Let us know if you have some more specific questions.
Micaela
Micaela N
(3,971 Views)
Its fairly straight forward, just measure the volt drop across the resistor.
I put the resistor in the return path on the low potential side, I also use 12v rather than the standard voltages. Just in case........ however
Watch our for floating power supplys though !!!
(3,929 Views)
