Signal Conditioning
Does NI have this: 1 to 1 signal conditioner (0-10v), high impedance input
Greetings everybody,
I'm asking about a product with these specs:
- Input: 0 - 10 volts (The input is high impedance)
- Output: 0 - 10 volts (Should be low impedance)
- Number of channels: One
Thanks in advance
Ayman Mohammad Metwally
Automation Engineer
Egypt - Cairo
(4,339 Views)
You could use a simple op amp circuit in the voltage follower configuration
(4,325 Views)
Ayman,
Are looking for some stand along signal conditioning device that you can build into your circuit, or are you looking for a signal conditioning unit to pass inputs into  a DAQ device. If you are looking for some stand alone component, then I would take AnalogKids advice using a Op Amp voltage followe. If you are looking for something to pass inputs to a DAQ device we offer several signal conditioning solutions. You can find them at the follow links:
SCC
SCXI
If you need any more help with that, please clarify what you are looking to use this for.
-GDE
(4,318 Views)
Thanks alot AnalogKid2DigitalMan,
But Im' not sure if I understood this !
SCC
SCXI
Thanks GDE for you offering,
Actually I have my PCI DAQ card (6251) and I only have one analog signal to be conditioned this way (1 to 1).
SCXI system is certianly more than I need, Maybe I have to check SCC.
Thanks.
Message Edited by Ayman_Metwally on 03-22-2006 03:51 AM
Automation Engineer
Egypt - Cairo
(4,312 Views)
Ayman,
Yeah SCC is a good alternative if you don't need the performance of SCXI. Take a look at the SCC-AI Module you will also need a carrier to put it in and connect to you DAQ card with. Take a look at those links, and see if those will fit the bill for you. Good luck with everything.
-GDE
(4,300 Views)
Ayman:
This document may help explain the voltage follower I mentioned:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P84RSAS&l=en-US
And also this discussion:
http://zone.ni.com/devzone/conceptd.nsf/webmain/CD57A73721E0612586256BAE0055CDD9?opendocument
Message Edited by AnalogKid2DigitalMan on 03-22-2006 12:34 PM
(4,293 Views)
