Signal Conditioning
AO missing 1st output when triggered with AI/StartTrigger
I have MIO-16xe-10 card, and am trying to start output and acquisition simultaneously using daqmx. I have copied most of the diagram from the Multi-Function-Synch AI-AO.vi example (see the attached vi). When I try to run it with only 1 iteration (that is, when the AI-AO happens right after the configuration) it works fine. But when i do 2 or more iterations, from iteration 2 on it "forgets" to output the first point to AO. I can see it on the oscilloscope, too.
The question is: why?
Thanks in advance for your help,
-Alex
http://forums.ni.com/attachments/ni/250/9842/1/write%20and%20read%20pulses%20(dev).llb
Message 1 of 1
(3,513 Views)
