Signal Conditioning
SCXI-1112 Calibration
Is there a procedure to perform calibration on a SCXI-1112 module?
(4,134 Views)
The SCXI-1112 User Manual also has some information on the calibration procedure and more specifics on it.
In general, you will be using the SCXI Calibrate.vi in LabVIEW. The Help on this VI should be enough to get you going.
Good luck.
Jared A.
(4,133 Views)
I m kind of insteresting to know how to build up the VI to calibrate the SCXI 1112.
(4,087 Views)
You can actually view the block diagram of both the SCXI calibrate.VI and the DAQmx Self calibrate.VI. As you will see, they both call a dll.
LA
(4,078 Views)
