Signal Conditioning
Asking for the Calibration Model for scxi1000
I m using LabView 7.1 ans national instruments SCXI1000. However, i don't know how to get the calibration on the SCXI1122 and SCXI1102.
For the calibration, do i need to build up the VI program? if yes, can provide some example or further information?
(4,254 Views)
No on cane sharing out some suggestion?
(4,226 Views)
I just sent you an email through NI, but I did not know which modules you were using. Now that I do, I am going to link to the documents that discuss calibrating both of these modules.
For the SCXI-1102, there is an SCXI-1102 Calibration Procedure Manual.
For the SCXI-1122, the calibration procedure is contained in the SCXI-122 User Manual.
In the email, I showed you the VIs to do this in LabVIEW. Have a Great Day!
George
(4,204 Views)
Hi George
I didn't recieved your email. Can you send it again? thanks in advance. The module that i use "SCXI 1322 and SCXI 1303".
(4,188 Views)
Here is the calibration procedure for the SCXI-1322 Terminal Block
Here is the calibration procedure for the SCXI-1303 Terminal Block
As far as calibrating in LabVIEW, I am attaching a screenshot of the VIs you will be using. Please use the context help (Ctrl-H) for a description and information on each VI.
I hope this helps, and have a Great Day!
George
(4,160 Views)
Are there any VI's in DAQmx to read/write/transfer the EEPROM calibration constants for modules such as SCXI 1102c and 1520? Right now I am only aware of the Trad DAQ VI's that can do this.
Matt S.
(4,062 Views)
Hi fsdaq,
There is no DAQmx equivalent for this VI. I recommend contacting NI Tech Support via email for any possible alternates:
Contact NI
Lesley Y.
(4,035 Views)
