Signal Conditioning
Automatic drift/offset cancellation in noisy spectrum
I have a noisy signal that contains 1-20 Hz spectral information. Its amplitude is  about 1 mV. This is originating from an infrared specrometer. The issue is the offset or baseline is continuously drifting at a random manner. I have to collect several spectra for averaging. But the drift associated with one set will be different from the next. Can anyone suggest a real time drift eliminating tool ?
(5,840 Views)
If you already transfer your data into the frequency domain, the DC part is your first bin. How about setting it to zero?
Greetings from Germany
Henrik
LV since v3.1
(5,802 Views)
