Signal Conditioning
I wish to control pneumatic proportional valve using NI 9263 but requires 5 mA control signal 0 to 10v
I wish to control a pneumatic proportional valve using the NI 9263 analogue voltage output module.  The module can only supply 1 mA and the valve requires about 0 to 10 volt @ ~5 mA. I have considered using an OP amp in unity gain buffer.  Any suggestions / circuit examples ?
regards Slopey
(5,938 Views)
We usually use an Analog Devices or Dataforth isolated 5B module 0-5Vdc input to 0-10VDC output. This seems to work nicely.
Tim
GHSP
(5,897 Views)
