Signal Conditioning
Borland C++ Builder compiling problem with Component Works V6
I receive an error compiling with Borland C++ Builder V3, V4 or V5 with Component Works V6 Active X Controls. For example, when I use TCWGraph Active X control I receive the following compiler error shown
below. I created a variant variable but cannot pass it without an error to the Active X Control. I have also used the C++ Builder example codes posted in the Knowledge Base (CWGraph and CWSerial examples) resulting in the same compiler problem. What do you
suggest to correct the compilation error? Thanks.
================ERROR=============================
[C++ Error] Unit1.cpp(41): E2015 Ambiguity between '_fastcall Variant::operator TVariant()' and 'TVariant::TVariantT(const Variant &)'
(5,471 Views)
The solution is to use the TVariantT structure which wraps a Windows VARIANT structure around VARIANT. TVariantT and TVariant are used to represent COM arguments and interfaces, just like the OleVariant class. However, TVariantT and TVariant are designed to work with C++Builder’s COM implementation classes that use the ATL, while OleVariant works with the VCL’s COM support.
The code to use for Borland's C++ Builder V4 for the TCWGraph example is the following:
TVariantT <(float)VARIANT> VarT2[100];
Variant vMean, vStdDev;
Variant data(OPENARRAY(int,(0,99)),varDouble);
int Bounds[2] = {0,99};
Variant A = VarArrayCreate(Bounds,1, varVariant);
int i;
for (i=0;i<100;i++) A.PutElement(rand()/10000.0,i);
//******TVariantT& operator
=(VARIANT& src)********
VarT2[0] = (VARIANT&) A;
CWGraph1->ClearData();
CWGraph1->PlotY(VarT2[0], 0, 1, true);
CWStat1->StdDev(VarT2[0], vMean, vStdDev);
MeanVal->Value = vMean;
StdDevVal->Value = vStdDev;
(5,471 Views)
I try this solution by coding them in a infinite loop and run it over two hours, it seems to has memory leakage because when I click "my computer" icon on the desktop I got an "not enoungh memory" message. Does anyone has any suggestion to get around this problem?
(My environment is Builder 5.0, Win2000 sp3.)
Variant A = VarArrayCreate( Bounds, 1, varVariant);
int i;
for ( i=0; i<100; i++) A.PutElement(rand()/10000.0,i);
//******TVariantT& operator =(VARIANT& src)********
VarT2[0] = (VARIANT&)A;
while( !isStop){
Application->ProcessMessages();
CWGraphDigitize->ClearData();
CWGraphDigitize->PlotY( VarT2[0], 0, 1, true);
CWGraphSpectrum->ClearData();
CWGraphSpectrum->PlotY( VarT2[0], 0, 1, true);
(5,471 Views)
