Signal Conditioning
Can I connect Endevco's 7265A-HS Model Peizoresistive Accelerometer to the NI-4472 directly without any Signal Conditioning hardware?
On reading the Specs of Endevco's 7265A-HS Model Accelormeter (attached to this message), it seems like the output of the transducer can be directly connected to NI's DSA Card. The excitation, ofcourse should be provided externally with a 10V dc source. Apart form this, is there any other signal conditioning requirement that I am missing out? Can somebody please advise?
Geeth
(3,169 Views)
The only other accessory that one would need is some type of SMB100 female to BNC female or SMB110 female to BNC male cable for however many inputs you may have.
(3,169 Views)
