Signal Conditioning
Can I programmatically access info set up in MAX?
I am programming an application that will be sampling multiple channels across several SCXI modules. All channels have been set up as virtual channels in MAX. I would like to be able to programmatically access the setup information contained in MAX (i.e. channel name, offset, scaling, etc.). Is there a way to do this in LabView?
(3,266 Views)
I did a quick search for a program that might do this and I ran across one here. Take a look at this program and let us know if it accomplishes what you are looking for.
However, if you are using DAQmx, this is currently not possible. Please refer to the following KnowledgeBase for more information.
Justin T.
(3,266 Views)
This is exactly what I was looking for. Thanks.
(3,266 Views)
