Signal Conditioning
Can I use a BNC-2090 with a SCXI-1520?
Is there a cable that connects the BNC-2090 to the front of a SCXI-1520 without using a terminal block such as the SCXI-1314?
(3,280 Views)
Or, Can I use a SCXI-1305 BNC Terminal Block with an SCXI-1520?
I will be using the SCXI-1520 to measure voltages. I need the gain and filter capability of the 1520, but not the shunting or 1/4,1/2,or full bridge capabilites.
Kevin
(3,277 Views)
From my knowledge, there are no cables that connect a BNC-2090 to the front side of an SCXI-1520. The SCXI-1305 is not designed for the SCXI-1520, so I don't think you would be able to use this terminal block with your 1520 either.
Hope this helps!
LA
(3,273 Views)
